Where do I add transmission fluid 99 camry le
Google
Web AF
mikedw
09-25-2005, 08:45 AM
ok stupid ? but I am low on transmission fluid and I know there must be a leak or issue somewhere but until I can get it checked out, I need to add some. My question is, where do you add it - I can't seem to find the place to do so in a 99 le v6. Also, how do I know HOW much to add... any help would be greatly appreciated and thanks
popeye08
09-25-2005, 09:47 AM
You have to add Transmission Oil to the hole that the stick located for checking oil level. Add a little not too much, and start the engine, D-R-N shift several times and check the level use that stick and add some more, untill it is between two mark.
Soilent Green
09-26-2005, 07:33 PM
English please?
ctuagent117
09-26-2005, 09:58 PM
for the love of christmas my mom has a 99 camry and here is what you do. there is a dip stick to the right of the oil dip stick. ahhhhh. ok now you take it out , it has an orange top i believe take that stick out. after you take that stick out, add tranny fluid in there not too much though, keep putting the stick in and out untill its at full. the stick will have marks on it to guide you, just like the oil dip stick. after wards just run your gears from p down to L up and down about ten times so it distrubutes around all the teeth. your finished. P.S. this is y i dont like automatics.
ctuagent117
09-26-2005, 09:59 PM
popeye is ttrying to screw you over dont do that. dont put trnny fluid in ure oil dip stick. ill see to it that he gets kiked out of this forumn for giving that advice. grow up popeye
mikedw
09-26-2005, 10:08 PM
I think what he meant was - add tran fluid to the dipstick where you check the tran fluid lvl, which is what I was told at the auto parts store
ctuagent117
09-26-2005, 10:10 PM
ohhhh...sry didnt really understand what he was saying it seemed like he said add trnny fluid in oil dip stick hole
Brian R.
09-26-2005, 10:26 PM
Are you guys sure? This sounds like a dealer-only job...
J/K
ctuagent117
09-26-2005, 10:32 PM
i dont know if it is im screwed. i did this same method to our 99 camry le. on my jetta it doesnt have a dip stick it has a plug which you have to take to dealer. never took the camry to dealer. just put fluid in.
Brian R.
09-26-2005, 10:35 PM
Don't listen to me. I was just giving this thread a hard time. The procedure is sort of what everyone was saying, but I'm not positive what they were saying... :confused:
ctuagent117
09-26-2005, 10:37 PM
theres probably another way to do it, but we had a meredes staion wagon with a severe leak from tranny and that was the way we always put the fluid in it lol, pretty pathetic now that i think of it
Google
Web AF
