92 possible blown fuse
GunsnRoses88
09-22-2005, 05:57 PM
my stereo quit working i have an aftermarket full system,,,, all connections seem fine,,, it wont turn on at all,,, if this was a blown fuse where could i find this fuse and find out if this was the problem?
GunsnRoses88
09-22-2005, 07:28 PM
can anyone help me locate the fuse that would effect the stereo?
mpumas
09-22-2005, 10:53 PM
Does your cigarette lighter work? If it does, it is not the fuse. If both the radio and cigarette lighter doesn't work look to fuse no. 11 (10amp.) Also check the ground wire. (blk). Power comes in on the yellow/red wire at the radio.
GunsnRoses88
09-22-2005, 10:56 PM
i dont know if it works but the green light that goes around the lighter is on,,,, i did notice that the clock was messed up?
mpumas
09-22-2005, 11:11 PM
No, the cigarette lighter itself. When you turn on the key, power goes to the radio and the cigarette lighter power relay. When the relay activates, the cigarette lighter works. The relay is used so that the large amount of current to operate the lighter doesn't have to go through the ignition switch.
