93 luminawynde 09-22-2005, 03:53 PM Can anyone help me please! I have a 93 Lumina and I had the codes read on it yesterday. The man said that the codes stated that I needed an ect. I bought one but, I dont know where it goes. He said it was on top of the motor and that I would be able to see it, but I can't find it. Help me PLEASEEEEE! Thank you, Wynde maxwedge 09-22-2005, 04:07 PM Possible you could post the codes, maybe we can help you out here. what was the original problem? richtazz 09-22-2005, 04:12 PM by ect, do you mean coolant temp sensor? wynde 09-22-2005, 04:33 PM Possible you could post the codes, maybe we can help you out here. what was the original problem? I dont have the code but the past 2x that I have filled up, after a few minutes, the check engine light comes on and it starts acting like I have fouled out a plug. I tooke it to auto zone where they ran the codes and that is what they told me, the etc...electronic cooling sensor, wynde 09-22-2005, 04:34 PM by ect, do you mean coolant temp sensor? Yes maxwedge 09-22-2005, 04:51 PM Should be on the thermostat housing but the circuit should be checked out first, under the throttle body, you will have to drain some coolant first. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
