2004 High RPM problem
Google
Web AF
GlenJetta1
09-22-2005, 02:17 PM
I just bought a used 2004 Jetta. Problem is, it tacs at 4,000 RPM when going 75-80 MPH. It will not go into an overdrive. I'm spending way too much on gas with this thing. Took it to the dealership and they said everything checked out normally. I am CERTAIN something is wrong here! I test drove 3 other Jetta's (same year, same model) and none of them went above 3,000 on the freeway. Anyone else have this problem? More importantly, is this a problem?
boschmann
09-22-2005, 08:24 PM
Check to see if the tire size matches the printed size sticker on the door jamb.
grandmastergd
09-24-2005, 03:01 AM
One other idea, take it in and get the "adaptation status" and "basic settings" done by a tech with a scan tool. I have had a couple of cabrio's have the same problem. Usually from a dead battery. If there has been any work done on it where the battery has been disconnected, it MUST be done!!! good luck
GlenJetta1
09-24-2005, 05:37 PM
Thanks for the advice. If I can get the dealer to ADMIT to a problem, maybe they will do as you guys suggested.
Glen
ocfire
09-24-2005, 07:06 PM
Anyone have torque specs on 2.0L jetta for cam
Google
Web AF
