leak stopper in T-Case?Bernando1 09-22-2005, 12:21 AM My T-Case leaks, and I am a poor boy. Can I add just a little bit of Transmission leak stopper to the T-case to plug it a little bit. thanks- The_Penguin 09-22-2005, 08:15 PM Where's the leak coming from? Some of the seals are pretty easy to replace. qb1384 09-22-2005, 10:57 PM I am having the same problem out of the front drive shaft. The_Penguin 09-23-2005, 12:06 AM I am having the same problem out of the front drive shaft. The front output seal is pretty easy to replace. If you can get the nut off the yoke, the rest is a piece of cake. Disassemble the U joint, Drop the front shaft,remove the yoke, and pry out the old seal. Tap in the new one, re-assemble and away you go. Take the model and assy numbers off of the TC when you go to get the seal, depending on which year and which TC there could be several. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
