speedometer calibration
pckx
09-20-2005, 03:55 PM
i have a 95 Camaro z-28, just bought it, and the mph is off by like 20. I'll be driving at 60 on the gauge and im really only going 40-45. My friends say that its got a new rear, so im tryin to figure out how to recalibrate the speedometer. Also the governor kick's in at 115 on the gauge and it's only like 90 can someone help!!!
skibum1111
09-20-2005, 03:58 PM
If the rear was changed and the gears are different, your computer needs to be altered to show the different gears, I think in 95 you need a custom burned chip but i'm not too sure about that part.
ct91rs
09-20-2005, 11:33 PM
That's a great question. I'd think that if it's OBD I you would need a custom prom, but if it's OBD II, I believe you could have it reflashed.
Genopsyde
09-20-2005, 11:38 PM
is it auto or manual? i've heard that the the 4-speed autos in early 4th gen models is almost exactly the same as the 700r4, and for my 3.73's i had to get a different set of speedometer gears that are inside the tranny tailshaft. I don't know if this helps or not because i don't know if it applies to your application as well.
ct91rs
09-20-2005, 11:43 PM
Interesting, I didn't know that.
http://www.transmissioncenter.net/speedometer_calibration_______va.htm
Genopsyde
09-21-2005, 12:01 AM
yea, i read about it in a Chevy Hi Performance mag article, they did the exact same ratio as I did, and they also put a address for thirdgen.org's tech article on it saying that it's where they got their info from.
FormulaLT1
09-21-2005, 02:18 AM
95's can be programmed for your gears. Find out what gears you have and I may have a program already done up for your car with that rear.
pckx
09-21-2005, 02:34 PM
yea its a automatic, but i don't know what gears are in it i'll try and find out
SG007
09-21-2005, 03:37 PM
I have a stupid question. What happens when you replace a 0-120mph speedo with a 0-150mph one?
Matt365
09-21-2005, 04:04 PM
reprogram?
FormulaLT1
09-21-2005, 04:23 PM
If you have a VSS its fine, if your gear driven. I think it needs to be replaced.
