97 Jeep Grand Chekrokee StallingERIC2000 09-20-2005, 10:09 AM My 97 Jgc Stalls On Long Trips. It Has New Plugs Wires Pcv Cps It Won,t Do It Any Other Time Any Ideas Would Help JeepForever 09-22-2005, 10:45 AM Could be the Crankshaft Position Sensor (CPS). Do a search in this forum for "CPS" and "Stalling". There's been some discussion on this recently. Does it stall while driving or idling (or both)? ERIC2000 09-22-2005, 02:55 PM IT ONLY STALLS WHEN I AM DRIVING NOT AT IDEL OR IN NEUTRAL OR PARK IT REVS FINE BUT WHILE TRY TO DRIVE IT CUTS IN AND OUT. IF I FLOOR IT IT JUST SITS AND THE TAC FALLS WHEN I LET OFF THE GAS IT SOMETIMES PICKS RIGHT UP THE CPS IS NEW THANKS Caribbean ZJ 09-22-2005, 03:19 PM Sounds like ur throttle position sensor myjeepsux420 09-22-2005, 06:52 PM Fuel pump ERIC2000 09-22-2005, 07:26 PM Thanks I Will Try Tps And Fuel Pump This Weekend Better Than The Dealers Ideas New Tranny And Motor Re Build Thanks Will The Ideas CCh2282 09-23-2005, 03:31 PM IT ONLY STALLS WHEN I AM DRIVING NOT AT IDEL OR IN NEUTRAL OR PARK IT REVS FINE BUT WHILE TRY TO DRIVE IT CUTS IN AND OUT. IF I FLOOR IT IT JUST SITS AND THE TAC FALLS WHEN I LET OFF THE GAS IT SOMETIMES PICKS RIGHT UP THE CPS IS NEW THANKS I had the same problem your haveing with your jeep I still have my jeep and I solved the problem BY changeing The map Seser ON the truck located under the throtel it's very easy to change its a Black flat Sencer right infront underneath the throttel That solved the stalling a HIgh Idling on the jeep vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
