Leaking Radiatorbyerjv 09-18-2005, 05:32 PM I have a 1995 Camry. The radiator is leaking near the very top, front, along what looks like a seam pressed toghther with a series (about 100) of small metal tabs. HOW CAN I FIX IT? Seems like it could be welded or soldered without removing the radiator. Comments? Jeff Toysrme 09-18-2005, 06:14 PM Don't do it... They leak for a reason. Normally either the coolant is not flushed often enough - causing it to become highly corrosive. Or You mix Toyota red coolant, with any common coolant. That will cause the two antifreeze types to turn into a very hard gel that is incapable of being cleaned, or flushed. Replace the radiator for a new one. $60-$80usd to get an aftermarket one. I you also need to change the thermostat, and once running, be sure the water pump is pumping OK. They can also clog, or have their impellors corroded off - impeading flow. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
