97 jgc pcm shuts off ASD relaybert2515 09-17-2005, 12:52 PM Cranks, but no start. checked for V+ at coil. none. checked at ASD relay. has V+ in but not out. Codes 11,12,42,55. Dale Aeppli 09-17-2005, 05:00 PM Cranks, but no start. checked for V+ at coil. none. checked at ASD relay. has V+ in but not out. Codes 11,12,42,55. There are three fuses in the power control box next battery-cavity # 10- is a 20 amp. Yellow fuse. (auto shutdown engine controler ). CAVITY # 11-15 AMP. blue (Auto Shutdown, Oxygen sensor). cavity # 18--25 amp natural color--(auto shutdown) check the wires on oxygen sensor that they are noy broken or burnt. 12-55 are telling the computer is working and the 55 is end of codes. 11--Camshaft signal or ignition signal --no reference signal deteched during engine cranking 42--Fuel pump or no auto-shutdown (ASD) relay voltage sense at controller. Dale check these fuses with a 12 volt test light, possibly the crankshaft sensor on the bell housing http://www.autozone.com/images/cds/gif/large/0900823d80152482.gif Shows the sensors 89ltd 09-21-2005, 08:13 AM auto shut down relay shuts fuel supply down and injector activity when the computer does not detect a spark. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
