View Full Version : 98 Cav "Knocking" noise while turning
Appleton
09-16-2005, 07:32 PM
Hey all,
Having problems with 98 Cavalier. When turning you can hear a noise almost like a knocking noise coming from the wheels. Hard to place exactly what it is. Checked the lug nuts to see if they were all tight and they were.
Also FYI. Just had new tires put on and just started to recognize the noise since.
Any ideas?
03cavPA
09-17-2005, 06:53 AM
Check the CV joints. Very common wear item in front drive vehicles.
Joe_Cool97
09-17-2005, 09:31 AM
yea sounds like your cv joints
Sagan33
09-18-2005, 12:54 AM
I have the exact same cavalier and it does the same thing. I just bought it so I dunno what it is exacty. Appleton post on here if you figure it out and I'll post if I figure it out also. But I had my cv joints looked at and all seemed to be ok. My buddy has a 90 grand am that does the same thing...He has had it checked out time and time again, changed the cv joints and all, and it still does it. I dunno it's weird!!!
Sagan33
09-18-2005, 02:16 AM
Can you tell which side it is knocking from? Mine is from the passengers side.
cousincletus
09-18-2005, 08:03 AM
Try lubing the slip joint on the steering column intermediate shaft.
mike dumar
09-18-2005, 01:32 PM
the car in question, is my car. Sagan that is exactly the same side where my noise is coming from
aside from sound, what other signs would i notice if it were to be a cv joint ? upon a quick visual look, the cv joint boot looks to be in good condition
something i came across last night while surfing the net, that i might try
You could have a loose caliper mounting bolt (figure A). These bolts can back off if you do not have a permanent adhesive like Lock Tight
what is disturbing about the situation, is that the sound did not occur until new tires were recently installed. I thought perhaps they did not balance the tire right, so i did a tire rotation, and still the problem occurs
chevboy
09-18-2005, 03:13 PM
Your Problem Is very common it is a strut mount bearing what happens is your strut turns itself into into the rusted bearing thus making knocking noise everytime you turn
Mod'd_Cav
09-18-2005, 03:17 PM
you guys ever try checking the bearings on the strut mounts..the seals could be worn out..especially on a 98 and now every time you turn your pulling the spring with it...if you can stay parked and when you turn the wheel it makes a loud clunking/knocking sound then try this...jack your car up from the frame..not the wheels..but make sure both sides are lifted off the ground..now that both sides are on jack stands..turn your wheels again..if the sound goes away its the strut mounts..if its still there its your CV joints
mike dumar
09-19-2005, 10:04 AM
sound only occurs, when im up past third gear, and when its a slight turn
under third gear i dont hear it
thanks for everyones help so far
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
