how can i change the wheel bearing on the front driver side of a "93 buick lasabree-money 09-16-2005, 06:02 PM how can i change wheel bearing on a 93 buick lasabre front driver side maxwedge 09-16-2005, 06:57 PM Do need step by step directions, have you done this type of repair before? LeSabre97mint 09-16-2005, 10:11 PM how can i change wheel bearing on a 93 buick lasabre front driver side Why do you need to change the bearing? Noisy? I would check out a book from the Lib. This job isn't too bad if you have the tools and a place to work. Dan HotZ28 09-17-2005, 10:08 AM You need to replace the hub & bearing assy. Remove large nut from hub and replace with new unit below. TIMKEN WHEEL BEARING/HUB ASSEMBLY-FRONT for a 1993 BUICK LESABRE Part No. 513087 (Auto Zone) Cost about $140.00 yogi_123rd 09-18-2005, 08:30 AM Bearings whine when they start to go bad. The bearing is part of the hub assembly. You will need a 36MM socket to break the axle nut. The brake caliper needs to come off The rotor needs to come off You will need a 55 Torx bit to remove 3 screws retaining the bearing assembly and a hammer to pound the bearing assembly out. Not a big job. yardmechanic 10-19-2006, 03:10 PM Any idea on the torque for the three torx bolts? I'm doing a set on my 93 today. Thanks, Gary maxwedge 10-19-2006, 03:27 PM Gary, in the future start a new thread, this is over a year old, 45-50 is about right. rhandwor 10-19-2006, 06:02 PM I use a press to remove and install front wheel bearings. What do you you use to hammer them in and out. How do you keep from damaging the new bearing. Do you put a piece of steel plate over the bearing. HotZ28 10-19-2006, 08:27 PM POSTING IN CLOSED OR OUTDATED THREADS: Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. This thread has been locked, due to the age of the thread (1+ yr)! Automotive Network, Inc., Copyright ©2013
