Page updated on 06-21-2018
2000 Lumina TCC stuck on
bheston
09-15-2005, 10:09 PM
I have a 2000 Lumina that was acting up on occasion, and registered a trouble code that said the torque converter clutch was sticking on in the transmission.
I guess the TCC is controlled by a solenoid that can stick and may need to be replaced, is there anything else I can check before tearing into the tranny to replace this solenoid? Has anyone done this, and how hard of a job is it? I have done a lot of engine work but limited transmission work, but I would like to fix this myself, so if anyone has any advice on this I would really appreciate it.
Thanks
Bob
maxwedge
09-15-2005, 10:17 PM
This should be scanned with a trans capable bi directional scanner that can command the tcc on and off, this will confirm whether the solenoid is the problem.
bheston
09-19-2005, 09:52 PM
I think I have narrowed the problem down to the TCC solenoid sticking on, and I need to replace it. Where is the solenoid located, is it a major job to replace it? Any advice on this is appreciated.
maxwedge
09-20-2005, 12:47 PM
The solenoid is in the auxiliary valve body inside the trans side cover.
jeffcoslacker
09-20-2005, 01:00 PM
http://autorepair.about.com/cs/doityourself/l/aa011703a.htm
bheston
09-20-2005, 02:17 PM
Thanks for the help guys, I think we will try to get this fixed this weekend.
Bob
