Cruise Control on 92 SEJim Rockford 09-15-2005, 03:49 PM I've been haveing problems with my cruise the last few days, Sometimes it refuses to set and i'll have to turn it off and on a few times to get it to set, Then while it is working it'll slowly start going slower and if i'm going down a hill it'll shut off and not reset and sometimes it'll jsut shut off while going steady. Has anyone else had this problem and if so how do i fix it. cnatsu1 12-10-2005, 08:21 PM I've been haveing problems with my cruise the last few days, Sometimes it refuses to set and i'll have to turn it off and on a few times to get it to set, Then while it is working it'll slowly start going slower and if i'm going down a hill it'll shut off and not reset and sometimes it'll jsut shut off while going steady. Has anyone else had this problem and if so how do i fix it. I've got the same problem. Seems like a relatively common problem at least according to the following link. I've replaced some vacuum lines and have looked at the brake switch. Unfortunately Chiltons doesn't tell me how to adjust the brake switch. Chiltons does show me a diagram of what a properly adjusted brake switch is supposed to look like, but I can barely get to it to get a proper view of the position it's in. Anyone have more info on adjusting the brake switch or testing it?? http://auto.consumerguide.com/Auto/Used/reviews/full/index.cfm/id/2092/act/usedcarreviewreliability/ I called the shop and they won't look at for less than $90. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
