1991 rear end idloggerman76 09-15-2005, 12:15 AM could someone tell me what kind of rear end my 1991 rs camero has in it ,its the original one that came in it. 7.5,8.5,8.8?? what about the ratio? i want to put a locker in it, and maby a set of lower gears. what is a good street/strip gear ratio?? thank you ct91rs 09-15-2005, 12:20 PM could someone tell me what kind of rear end my 1991 rs camero has in it ,its the original one that came in it. 7.5,8.5,8.8?? what about the ratio? i want to put a locker in it, and maby a set of lower gears. what is a good street/strip gear ratio?? thank you Ring gear should be 7-5/8 (located on bottom center of i.d. tag) '91 RS axle ratio - V6 manual trans: 3.42 auto: 3.23 V8 manual trans: 3.08 auto: 2.73 Sure you want lower gears? Most people want higher gears, you lose a bit of top speed, but it gives you more low-end torque. If you want to keep it streetable, as a daily driver, I wouldn't go higher than 3.73. tcfco2005 09-15-2005, 12:44 PM ya dont go over 3.73's id probably go with either 3.73's or 3.42 i have 3.42 and i enjoy them alot....i even get better gasmilage then when i had my 2.73 loggerman76 09-16-2005, 04:32 AM im looking to install a locker/spool any suggestions? how do i tell if its a 28 spline? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
