1992 Lumina tcc solenoid wire locationlemondsc 09-13-2005, 08:36 PM Can Someone please tell me where the wire to disconnect the tcc solenoid is located at on my car. From the other posts about luminas stalling out after getting warmed up I believe that my solenoid might be the problem but I need to know what wire it is that I need to disconnect to see if that is the problem. Any help would be greatly appreciated. Jonn 09-14-2005, 07:28 AM Can Someone please tell me where the wire to disconnect the tcc solenoid is located at on my car. From the other posts about luminas stalling out after getting warmed up I believe that my solenoid might be the problem but I need to know what wire it is that I need to disconnect to see if that is the problem. Any help would be greatly appreciated. stand with feet placed at drivers side tire, lean over car over top transmission, look straight down, you will see the alum. bell housing bolted to the engine, toward you is the transmission body, on the left side (your left) of transmission body is a plug in near the top of the transmission body, toward the tire you are standing at, i believe the plug is blue in color, its sorta below battery box/air cleaner, near the pan thats bolted onto the END of the transmission case, upper most part. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
