Vibration During acceleration95redTA 09-13-2005, 08:20 PM I have a 1995 Pontiac Trans am LT1 with the automatic transmission no performance mode button. When accelerating I have a bad vibration from 40 to like 60 mph anyone got any ideas i'm thinking maybee motor/transmission mounts. It doesn't do it if I accelerate hard or if i accellerate really softly, only if i use a medium accelration. also trans fluid is where it should be Also i have a oil leak it seems to be from the front and the back parts of the motor and when the car is at temp sometimes i will get smoke from the back of the engine because of it buring the oil I guess any ideas on that blindeyed 09-13-2005, 09:09 PM Could be a bad U-Joint. Check both ends of your driveshaft to see if they're still secure. Also, it might be your tranny mounts going bad. Try getting a crow bar up beside your tranny and see if you can wiggle it back and forth. If you see your tranny moving, then your mounts are bad. FormulaLT1 09-13-2005, 09:12 PM Generally vibration like that is caused by the steel unbalanced driveshaft in LT1's. There was a GM service bulletin issued in regard to it and it is very commen. A easy fix is to replace the steel unbalanced driveshaft with a Aluminum balanced driveshaft like the one's used on the LS1, a side bonus of doing this is added power to the ground cause of the aluminum shaft weighing 1/4+ less. If you need one of these let me know as I have supplied many other members with them. Also a commen vibration problem can be caused by damaged mounts but since most times that type of vibration would be felt stronger at take off than highway speeds, also U-joints would cause a clunking as you started off then as speed increased would become less noisy and produce less vibrations. Good luck to ya. John Matt365 09-13-2005, 10:07 PM might also be a bad torque converter. 95redTA 09-15-2005, 09:03 PM Well mounts were fine, talked to a guy that works at a transmission shop and he said from how I explained it, it's most likely the torque converter also said it'd be about 400-500 to replace including labor, is that a good price? FormulaLT1 09-15-2005, 09:28 PM That sounds like a good price to, Matt365 09-17-2005, 01:45 PM yea, thats a good price. I recently had the converter and other things replaced in my transmission. Believed a new torque converter cost, here it is, cost me jus under 300 dollars just for the part. And the installation is quite frankly a cold hard bitch. To do it, hes gonna have to take off exhaust, drive shaft, drop the transmission out, then he can get to the converter. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
