Auto. transmission problemsrobunicu 09-12-2005, 04:02 PM Hi, I have a 95 ex 2d. automatic. I bought it with 700$ from a lady, she did not put any water, and the engine blew. i replaced the engine. with 100k miles on it. i had my cuzin install it. the car seems to work fine but when i put it in drive, i start driving.....and sometimes it does not shift gears...it does not go into second or third sometimes,i have to let go of gas and then it shifts....any idea what i have to do? i was thinking the transmision overheated of something...? should i buy another transmision..i dont really want to do that.... any help will be apreciated. thank you lots. i_a_n112784 09-12-2005, 06:49 PM I hate to tell you, but automatic transmissions have to be cooled, that trans overheated as well as the original engine, Try changing the fluid, see if that helps, but there could easily be internal damage, in which case you might be better off getting your hands on another, plus torque converter. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
