no signal lites
sg7z
09-10-2005, 10:00 PM
I noticed my right rear marker lite was out and my turn signals not working either. All other lites seem to be fine. I looked at the manual and cant find any specific fuse that may cause this. I already changed the marker lite bulb, but it still isnt working. Any ideas????
Thanks,
Perplexed
Blazerboy1287
09-11-2005, 07:33 AM
there is a possibility that it may be a short or break in the wires heading to those lights, which you could check using a continuity tester, if you can find out which wires do that...
Another possibility, since your turn signal is involved, is that there is a relay that is not functioning properly...
Used to have an '87 Camry
sg7z
09-11-2005, 08:00 AM
Thanks Blazerboy. I'll check that out.
Mike Gerber
09-11-2005, 11:55 AM
The most common spot for a break in the wires leading to the rear is in the loom of wires in the trunk by the trunk hinge on the driver's side. They have a tendancy to break there do to all the flexing from opening and closing the trunk.
Mike
