Rear Pinion Sealhrlayton 09-09-2005, 09:15 AM Can someone tell me how to change the rear pinion seal on a 1991 Ford F250 4wheel Drive? mrfixit64857 09-09-2005, 06:36 PM 1. remove driveshaft. 2. remove nut holding flange 3. remove flange 4. use slidehammer with hook to force out the old seal to the front of the vehicle. Tap in new seal, install reverse of removal. way2old 09-09-2005, 07:12 PM If you don't have a slide hammer, you can use a sturdy screwdriver and hammer to remove the seal. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
