Driver Window off track
Alibi
09-09-2005, 12:49 AM
1986 88 (1986 bonneville door)
I was just wondering, how does one install a new window guide clip in a driver's side window? I assume it involves taking the door panel off?
Alibi
09-13-2005, 08:46 PM
Ok, still cant figure it out.
I took the panel off today and I couldn't figure out a way to get the guide in.
I tried clipping it to the window, greasing up the clip, and shoving it between the pieces of trim but i couldn't get it to slide all the way in.
Is there some special trick to this? Help! I need ventilation! :confused:
turtle_time85
09-25-2005, 07:13 PM
any luck yet? how do you know the clip is broken and just not off track?
you might have to remove the "ribs" i guess you would call it.
Alibi
09-25-2005, 09:22 PM
Nope, no luck yet. The clip is gone for sure -- the window will slide sideways and the hole where the clip is supposed to be is obvious.
ItsA88
06-07-2006, 02:42 PM
I am having this problem right now as well....
Anyone figure it out. Motor works, but window won't go up or down.
Alibi
06-08-2006, 09:11 AM
Really old thread....
Anyway, I never did get it to cooperate, but I ended up just giving that car to a friend of mine who helped me work on it. However, I think I have seen a tutorial on the net (dont know the link) that in order to get the guide back in you have to heat it up with a blowdryer, then clip it onto the glass, then just shove it back into the groove...this is with the window about halfway down.
I'll try to find that link for you...
ItsA88
06-08-2006, 02:06 PM
That link would be great. Thanks.
Alibi
06-10-2006, 12:43 AM
Umm..yeah...that was close to a year ago so I don't have the link anymore. I may be able to scrounge it up but you would probably have just as much luck searching the net for it as I would :(
Alibi
06-10-2006, 12:51 AM
I found a page that may be sufficient for you for the time being. I couldn't seem to get a direct link for it, so here are directions:
http://lesabret.com
"forums"
"Maintenance"
"Those Pesky Window Clips"
Fun fun fun... :(
