Help !!!!!!!!!!
sr20det350whp
09-08-2005, 09:40 AM
I Just Got My Sr20 Finally Dropped In. Im Leaking Oil Like A Bastard And I Have No Clue Where It Is Coming From, I Know Its Notcoming From The Oil Pan. But Anyways My Intercooler Piping Has Oil In It And So Does My Intake Manifold, People Say That My Turbo Is Blown But It Still Runs Like A Champ And Hitting 11 Psi. Can The Oil In My Intake Fuck Shit Up. Any Suggestion People I Could Use It
Peace Out And If U Aint Racing U Should Be
sr20det350whp
09-08-2005, 09:58 AM
I Forgot To Ask Im Not Leaking From My Oil Pam,turbo Lines,or My Cylinder Head Where Else Can I Be Leaking From, Its Driving Me Nuts!!!
D-Bo
09-08-2005, 10:16 AM
pump? where's it dropping down to the ground from your engine bay?
sr20det350whp
09-08-2005, 10:51 AM
ITS LEAKING FROMTHE CROSS MEMBER BEHIND THE OIL PAN AND DO U KNOW IF THE OIL IN MY INTAKE WITH FUCK SHIT UP
SHIFT_KA24DE
09-08-2005, 12:44 PM
be funny if it was just a loose oil filter. =P
oil in your intake? it's gotta be your turbine... unless you got some oil cooler rigged up with your "cold air" intake....
D-Bo
09-08-2005, 12:59 PM
fuck shit up? probably not.. if anything it'll leak into the cylinders and burn.. but thats not a good thing anyways.. i'm not sure how it got there though, if anything its from the turbo
driftking777
09-08-2005, 01:06 PM
take some pics...that would help alot...
sr20det350whp
09-08-2005, 01:34 PM
I Just Did A Oil Change Yesterday And Changed The Filter. Right Beside The Filter There Is This 4ft Black Line That Goes Across The Engine Bay And On The End Is A Silver Ball. I Was Wondering What The Hell It Is.
D-Bo
09-09-2005, 12:20 AM
probably a black line with a silver ball on the end..
Tims_240
09-09-2005, 12:25 AM
alright, if its going into your intercooler piping, that could mean that your turbo seals are blown. is this a stock sr20, or do you have an upgraded turbo/turbo oil lines.
because alot of people dont realize that you have to have a 1/8"(if im not mistaken) restrictor or you will feed your turbo too much oil.
that is the only thing that i think it could be, check and recheck everything.
klone420
I'm guessin u put the oil filter on with the old ring still on there, or its ur turbo.
slideways...
09-09-2005, 12:53 AM
noooooo if his old filter gasket was still on there when he started the car there would be oil spraying EVERYWHERE
lost180
check the hose the comes from the valve cover to the charge pipe. the might also be where oil is getting into the intake... as far as it dripping.. clean your engine real good w/ degreaser. Then drive it around a little bit, then look for wet spots...
shawn_carter69
09-09-2005, 01:11 PM
omg like its sooooooooo obvious, it almost makes sense
