93 pontiac grand am won't start
Google
Web AF
angelfan
09-07-2005, 11:39 PM
I have a 93 3.3 grand am that wont start. I have changed the crank sensor, ignition module, wire harness, ECM,and coils. The fuel pump is working . It as spark on occasion but not enough to start it.
DaGrease
09-08-2005, 02:05 AM
I also have a 93 grand am and I had the same problem when i was at a friends house. I forget what way I turned the wheel but try turning the wheel as far as u can both ways. That did the trick
Werm9
09-09-2005, 06:29 PM
what about the battery? check the altenador?
raykjavik
09-10-2005, 01:57 AM
Did you check the computer?
Ridenour
09-10-2005, 06:17 PM
You never said you changed the plugs. Check / change the plugs and ignition wires before you get into anything more major; especially if they're original.
angelfan
09-12-2005, 08:08 PM
that's what the ecm is
angelfan
09-12-2005, 08:10 PM
The battery and alternador were good
angelfan
09-12-2005, 08:12 PM
Will spark plugs do that, I changed them but with bocsh supers if not that then what could it be.
skibum1111
09-12-2005, 08:26 PM
Try going with a stock plug, your coils might not be strong enough to spark a bosch like that.
Google
Web AF
