Location of Vehicle Speed Sensor (VSS) on 1998 Taurus?
paulstamser
09-07-2005, 12:07 PM
Hi,
Anyone know where the VSS (Vehicle Speed Sensor) is located on a 1998 model Taurus with V-6 engine and automatic transmission?
I know it's somewhere on the transaxle but not exactly where altho I looked as best I could.
I'm trying to help a friend fix her car and the Haynes book doesn't tell you where the VSS is located. Nor have I found good info on the internet about it.
Thanks much!
drdisque
09-07-2005, 05:00 PM
its plugged into the top of the transmission.
paulstamser
09-08-2005, 11:20 AM
I see that you list your Taurus as a DOHC. I think this one is a SOHC V-6 engine, so I wonder if there is difference in the VSS location between the two.
But I will look on the top of the trans.
Is yours towards the drivers or passenger side?
Thanks.
drdisque
09-09-2005, 01:24 PM
since certain transmissions were interchangeable between the DOHC and OHV, i believe its the same on both.
I haven't personally ever removed mine, this is the word from people who have, so I can't give you any visual clues on finding it.
paulstamser
09-10-2005, 11:10 AM
Okay. Thanks much for the feedback.
I may be going over there today to look at this Taurus. I'll see if I can find the VSS. It is almost certainly the problem. Dead speedo. Stuck in first gear (limp mode).
