Eclipse tranny question
jawzy_fizzle
09-07-2005, 03:01 AM
Hey everybody I have a 91 Eclipse GST and I need a new tranny. I found a five speed tranny out of a 1.8 non turbo, my question is will a five speed n/a tranny work for a 2.0 fwd turbo? Thankyou for any input. I also have a 91 3000gt 3.0 v6 N/A still runnin stock just above 200hp but anyway I have heard rumors that the trannys in 91 eclipse's will also work for the gto, and if that is the case I would rather fix my gto :-) you know what I mean... Again thanks for any input
talskinyguy
09-07-2005, 11:09 AM
The insides are the same, and the belhousings are different. What I dont know is if you can bolt the 3s bellhousing to the 2.0 fwd turbo trans.
Twizted_3KGT
09-07-2005, 11:29 PM
From everything I know the FWD Turbo DSM transaxles are the same as the FWD 3S transaxles. Both are the F5M33 (or 32).
Hotshot8792
09-08-2005, 08:56 PM
actually, i believe its just the auto tranny's that are the same in the DSM's as the 3/S's, but dont hold me to that.
Stealthee
09-08-2005, 09:31 PM
The internals are the same but one will not bol up with the other. The case is completely different.
jawzy_fizzle
09-09-2005, 03:11 AM
Thanks guys, I appreciate your time I am still unsure though... The tranny in my eclipse is stuck in second so I have been told that it would be fixable with a rebuild kit, but, the differential pin shot out of the case in the tranny of the 3s ... So should I rebuild the eclipse tranny? Or should I just buy two tranny's??? Thanks again
