Sideview Mirror ReplacementKenRosier 09-06-2005, 10:31 PM I have a complete replacement electric sideview mirror that I have to install in my 1996 Camry but I can'd figure out how to remove the small tringular trim piece located on the inside door panel just behind the mirror. It looks like it should just slide off but I've pulled in every direction and it won't budge. Someone please help! Ken Rosier KenRosier@aol.com Brian R. 09-07-2005, 01:16 AM Pry it off with a taped screwdriver tip KenRosier 09-07-2005, 10:58 AM Pry it off with a taped screwdriver tip I cranked on a very hard until I thought it was about to snap in half but I will give it another try. Does it pop straight out or does it slide upward or toward the rear if the car? Thanks! csaxon 09-07-2005, 11:51 AM Just pull and one snap will come loose. KenRosier 09-07-2005, 02:13 PM Thanks so much for the help. It sure will be nice to have a side view mirror again!!! Ken, jt5 09-08-2005, 04:40 AM If you haven't removed it already, the cover pops out from the very top point. Then just slide it up. KenRosier 09-13-2005, 09:32 AM It snaped right out with a little extra force. Thank for the help csaxon 09-13-2005, 11:11 AM Eat your wheaties! Good luck. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
