SeaFoam
Google
Web AF
czm400r
09-06-2005, 07:40 AM
I have used SeaFoam fuel as a system cleaner as long as I can remember, Why I don't know but I run a can thru the tank every 20-25k miles and have had no fuel related problems. The can does say that it can be used in the crankcase oil as a cleanup. Anyone use this in the engine before?
DINO55
09-06-2005, 08:20 AM
Seafoam is supposed to be some good stuff, I've never used it though, Do a SEARCH on seafoam, all of your questions should be answered then.
BlazerLT
09-07-2005, 03:15 AM
Heard of lots of people using it in their oil system as a slow flush.
1/2 a can in the gas tank, rest of the can in the crankcase, drive 500 miles and dump the oil and do an oil change.
BlazerBoyLT98
09-07-2005, 09:57 AM
I have yet to use seafoam, I think I heard it fouls plugs easily but I could be wrong. I really like Marvel Mystery oil in the gas tank and the price is unbeatable! Autozone $2.99 for a 32 ounce bottle and per 10 gallons of gas you use 4 ounces of Marvel Mystery oil. Basically get 4 treatments out of it. I like it.
BlazerLT
09-07-2005, 12:10 PM
Seafoam will foam the plugs when you suck it through the PCV line for combustion chamber cleaning.
Tangent
09-09-2005, 06:17 PM
I can't say I've ever heard of something "foaming" the plugs before...
BlazerLT
09-09-2005, 10:46 PM
It doesn't foam, it fogs the cylinders and removes excess carbon.
This can also be done with water which is what I use seing there is no residue.
BlazerBoyLT98
09-11-2005, 01:22 AM
Yea didn't you get your engine steam cleaned or something? Is that same day service you can pick up, or do they drop if off in a box pressed and folded??? hahaha I am cracking up! :lol2:
dmbrisket 51
09-11-2005, 12:00 PM
sea foam, your using it to often, but you are useing a great product... every few oil changes/ transmission services, 500 miles prior, put half a can into the fluid, and it helps thin it out and degrease the internals
BlazerLT
09-11-2005, 06:45 PM
It worked perfectly and didn't foul my plugs. Really happy about it.
BlazerBoyLT98
09-12-2005, 09:42 AM
How do they do it and what does something like that cost?
BlazerLT
09-12-2005, 10:08 AM
do a search for water cylinder decarbonization
BlazerBoyLT98
09-12-2005, 10:46 AM
Ok cool thanks
Google
Web AF
