99 Dodge Ram wont turn over.
phoneman1
09-01-2005, 09:04 PM
I was driving home from work today turned into my street and truck died, I tried to start and it won't even turn over,when you turn on the key there are no lights in the cluster that come on and none of the gauges move. I cleaned battery cables, swapped batteries with known good battery,checked fuses,all other electronics work fine, radio, lights heater,
Any help would truly be appreciated.
Thanks Phoneman1
Thanks Phoneman1
r00ster
09-02-2005, 05:55 PM
if you have tilt, set it all the way up and see if it fires then, could be loose ignition wires
phoneman1
09-02-2005, 06:19 PM
if you have tilt, set it all the way up and see if it fires then, could be loose ignition wiresI tried that but wth no luck I appreciate the response and would welcome any other suggestions.If there is any more information needed please let me know.
