'05 switched power wire under dash
Google
Web AF
jethro_3
08-31-2005, 08:58 PM
I am looking for a wire that is switched on from accessory and run position and off in the off position for an '05 Silverado. :1zhelp:
Help I am looking and done with everything but this one wire....
Thanks, :worshippy
Jethro_3
BlenderWizard
08-31-2005, 09:10 PM
Whatcha wiring up?
jethro_3
08-31-2005, 09:25 PM
Valentine One, the only way to fly, and I mean Fly Safely!!!!!
BlenderWizard
08-31-2005, 09:30 PM
Ah.
jethro_3
08-31-2005, 09:37 PM
I keep justifying it by telling my twins that I just want to know where the police are hiding when they try to help me. That is helping empty my wallet, helping me stay in the slow zone and help me make sure the other guy gets slingshot past me into the trap.....
sportin83
08-31-2005, 10:10 PM
12volts red (40A), red (40A) + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ignition harness
Power Lock use 457G or 456G module
Power Unlock see power lock
Lock Motor gray 5wi driver door module in door
Unlock Motor tan 5wi driver door module in door
Parking Lights+ brown + driver kick panel
Parking Lights- gray/black - switch or BCM, brown plug, pin B2
Hazards white - hazard switch
Turn Signal(L) dk. green + turn signal switch
Turn Signal(R) lt. green + turn signal switch
Reverse Light lt. green + BCM, black plug, pin F
Door Trigger gray/blk (L), black/wht (R) - each door module in each door
Dome Supervision gray/black + BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white ac instrument cluster, pin A5 or PCM
Wait to start dk. blue - instrument cluster, pin A2 or PCM
Brake Wire white + brake pedal switch
Parking Brake lt. blue - switch or BCM, lt. blu plug, pin A7
Horn Trigger black/yellow to black - switch or BCM, gray plug, pin B9
Memory Seat 1 red + driver door module in door
Memory Seat 2 pink + driver door module in door
Memory Seat 3 N/A +
this is the complete wiring of the vehicle under dash. you can use any of the accesorys it ignitions for what you want.
jethro_3
08-31-2005, 10:59 PM
Maybe I SAID IT WRONG. I am looking for a wire that is hot when the ignition is on, and Off when the ignition is off. I am under the steering column trying to find a hot for my radar unit. Where is the wire located and what is the color code so I can find it?
Thank You
sportin83
08-31-2005, 11:25 PM
Thank You
you want the accesory wire which is orange or you can use pink which is the ignition. it doesnt matter which one you use. they will both work and they should be a larger diameter wire than most. and will be located in the steering column under the metal shield in the under dash.
Google
Web AF
