Replace Hi-Lo Switch 1990 Corsica?freaker 08-30-2005, 08:03 PM Just had my hi-lo switch on my 1990 Corsica die ... on high beams of course! Now I get flashed all day and not in the good way! ha ha .. Can anyone give me instructions on how to replace it? Thanks in Advance jsgold 08-30-2005, 08:50 PM I bought a new switch for my 91 a few years ago, and then found that the switch was OK! the switch is actually near the base of the column and is controlled by a rod that runs thru the column and connects to your control handle. The switch can work loose a bit and the rod won't quite open/close the circuit, so you might be able to just pull back a bit and tighten. It is kind of cramped under there but be patient. Might have to remove a panel under there, I don't remember, but if you have a good light and are patient, it won't be tough. Look under there with a light and move the control handle, you will see it. freaker 08-31-2005, 06:39 AM Thanks! I'll have a look hopefully it's an easy fix!! freaker 09-07-2005, 07:08 PM Thanks JSGold, I was told by the local chevy dealer (service manager) that I needed to pull the steering wheel. After reading your reply I decided to give'er a look myself. Sure enough I think your answer was right but to be safe I replaced the switch anyway. Here is a quick step by step from my perspective: Remove cover under steering column (3 hex screws & 2 Phillips screws) Locate hi-lo switch (about half way between wheel and fire wall) Check to see if switch has moved, slotted holes will allow this Adjust if possible If not, remove 6 - 1/2" hex bolts that hold column in place A 10mm wrench removes the lower nut & 8mm the fwd bolt on the switch Remove wiring harness clip Reverse. NO REMOVAL OF STEERING WHEEL IS NECESSARY! Thanks again JSGold L8er Freaker vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
