sputtering and poppingaaron8409 08-28-2005, 11:27 PM I have a 1995 cav with 102500 miles. Today after work I started it up, and it was shaking pretty bad at idle. When I pulled out, it started sputtering and making a popping sound, but only at low rpms. Once the rpm's came up, everthing was normal. When I stoped at a stop sign, and pulled out, samething happened. The car was fine when I drove it to work in the morning. Just got the car a week ago, I changed the plugs, air filter, fuel filter, and did a compression test which was good. I did all this before the problem started, and it ran fine for a week. Any ideas? aaron8409 09-01-2005, 06:38 PM To be more specific on the popping sound, it is backfiring thru the the thottle body, when the engine is under medium to heavy load. ie. pulling out, not cruising. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
