32 11.50's fit 02 Tacoma??
Google
Web AF
jonnie12345
08-28-2005, 09:28 PM
would like to know if 32 11.50 BFG Mud Terrains will fit on my STOCK 02 tacoma. Has trd, sr5. These tires fit fine on my 00 , no rubbing, but I didnt know if the design changes from 00 to 02 would affect it. Thank you
ctesla
09-01-2005, 01:30 AM
30/31-10.5s do.
(and mine is a PRE-runner; 2WD)
but if you have a tire specialty shop in your area, I would definitely have them look it up in their catalogs, before swapping out, then, only to find out a right turn is going to end up a 6-pointer, because you only get a half turn on the wheel to lock.
hope this helps
Brian R.
09-01-2005, 02:52 PM
I'm looking for a cross reference to largest allowable tire size and truck year or generation. Any help?
ctesla
09-01-2005, 05:59 PM
Brian,
when I did outside sales for Pep Boys in Colorado,
we had an actual charting book (about 5x7 in size, about 300p) that gave OEM tire sizes depending on yr/mk/mdl, but also minimum and MAXimum allowance given ground issues and height clearances.
I'll make a couple of calls to old allies over the holiday to see if they still exist, or if any older ones are around, and the manufacter of the publication.
if you have any associates working at specialty wheel or tire outlets, they may be able to assist prior to me.
if I do conjour one up, you'll have to email an address, where I can ship to.
hope this helps,
chris
nrt racing
(will also PM this)
jonnie12345
09-01-2005, 08:07 PM
Thank you for the replies. still cant figure this one out. Les Schwab says no, but they said they wouldn't fit a 2000 either, so i dont know. I think they will, but i dont want to go out and buy them and not be able to turn all the way. Thanks
chester9ll
10-04-2005, 11:17 AM
i have a 2000 trd and am running 32-11.50 dunlops and they only rub when i am off road flexing the suspension hope that helps
tacolover
10-08-2005, 12:33 AM
hell no it won't fit. i was running a 2.5" fabtech lift on my 02 with 32x11.50 bfg mud terrains and they rubbed. had to trim some of the fenderwell out, and they still rubbed while articulating and turning. just recently put a 3" BL on. see pics at http://www.cardomain.com/profile/speedemon55
Google
Web AF
