rev limiter
mrpibsk8er
08-24-2005, 01:02 PM
my civic has a jdm d15b and it is supposed to redline at 8200, but it redlines at 7500 and I have a cel code of 21. do you think that is why my redline changed? I think that is the vtec solenoid. if so should I replace it? (my vtec still works though)
CivicSpoon
08-24-2005, 01:13 PM
what ECU are you using?
mrpibsk8er
08-25-2005, 04:59 PM
I am using the ecu that came with the motor. it used to have a higher rev limiter but then my cel light came on and now it doesn't have as high a rev limiter. it didn't come stock with vtec but now it has a vtec motor and ecu. and the vtec does work
honda_racing101
08-25-2005, 08:28 PM
Hows your oil pressure?
mrpibsk8er
08-29-2005, 01:51 PM
I believe it is fine I don't have a gauge. but the light doesn't come on while the motor is running
honda_racing101
08-30-2005, 08:39 PM
Is your oil old and shitty? If it is your ecu might put your engine on limp mode, maybe not tho if your VTEC still engages.
hany
08-31-2005, 09:15 AM
i think the red line in the D!%B vtec start at 7200 rbm . and the d15b vtec red line never run in 8000 rbm .
hany
08-31-2005, 09:17 AM
[QUOTE=hany]i think the red line in the D15B vtec start at 7200 rbm . and the d15b vtec red line never run in 8000 rbm
