car died! HELP
Google
Web AF
leadfootGTP
08-24-2005, 02:01 AM
A little info before we get into this: 1999 gp gtp, w/just under 100k, recently (3 weeks ago) installed DHP PCM and K&N drop in, with other mods being put in soon, depending on the severity of the problem. Havn't gotten around to having a case learn done yet (lazy/busy), but i put the chip in 3 weeks ago and everything has been running very well (as far as i could tell) up until today....
While driving to my girlfriend's house, my car shut down while idling at a stoplight. I turned the radio off, lights off, put it in park, and restarted it after a few tries. I drove to my girlfriends house, because i was pretty close, noticing that, while idling, my rpms were fluctuating quite a bit until i turned off my radio, once again, but no battery light, or any other warning light came on.
While driving home, i noticed the same thing. (decided i would take it in to a shop tomorrow, didnt make it) Going up a hill, i floored it to see what would happen (up until then i ONLY had problems while idling / starting, i wanted to see if this was the only time that these problems were occuring)
She shut off completely, no engine, no power steering/brakes. Pulled over to side of road. Tried starting, wouldn't, but it would try. All electrical worked fine (lights radio, windows, etc.) I waited for a while, after calling my mom for a ride, and then tried starting it again, a lot of clunking/bad noises, but it didnt start, so we pushed it to a side road/parked it.
Calling a towtruck/taking it to a mechanic tomorrow morning, but does anyone have any ideas??? This car has had absolutely NO problems up until now, mechanics had been offering to buy it from the people i bought it from when they took it in for oil changes, absolutely no signs of any problems, until now.
BNaylor
08-24-2005, 02:51 AM
It sures sound like its crankshaft position sensor related. Might want to consider the case learn since you put in that new DHP v1.0 PCM.
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
leadfootGTP
08-24-2005, 11:36 AM
yeah i definately am going to do that, i guess i was just putting it off. What i dont understand, though, is that it ram perfectly fine with the new chip for 3 weeks, absolutely no problems at all until yesterday. If it was a problem this big with the crank pos sens. wouldnt i have noticed something? The car has quite a few miles on it, if it isnt the chip, im thinking that it might be a fuel line problem, but we'll see i guess, car just got taken to my mechanic.
BNaylor
08-24-2005, 01:10 PM
Ignition or fuel. I guess you can flip a coin. Good luck and let us know how it turns out.
BTW - Nice ride! :bigthumb:
leadfootGTP
08-24-2005, 08:13 PM
MAF sensor. K&N drop in shorted it out, ironic, ii had just learned that GM dealers were voiding warranties on gp's w/ k&n filters because this was happening to some people. $300 to fix, could be worse.
Google
Web AF
