high beam flickers w/left turn signal
Google
Web AF
toyboyz
08-23-2005, 11:18 PM
My 92 has a problem with the highs coming on when I turn on the left turn signal. Try pulling back on the turn signal post just a little bit with the headlights on and see if that makes high go off. What do I need to do? :uhoh:
gator2764
08-24-2005, 06:09 AM
Will be happy when someone finally finds out how to cure this problem, I have the same thing happening in my 92!!!
jake1978
08-25-2005, 10:25 PM
I had that happen to an old van of mine. It ended up being a loose ground. Check the ground that bolts to the frame right behind the headlights. It's 4 wires crimped together (I think). Bad grounds can cause really wierd stuff to happen
Jake
toyboyz
08-29-2005, 02:40 AM
Okay, I finally made the time to take it apart. the high lights flicker cause the parts are just worn. Cheap plastic parts are just made to wear, cant complain, lasted 14+ years. I will just have to dish out the $$$ and pick up a new combo switch assy. At least I learned how the lights work now and can take it apart blindfolded now.
toyboyz
08-31-2005, 03:27 AM
I installed the new combo switch and everything is Good.
gator2764
08-31-2005, 06:29 AM
How much did the switch cost??
toyboyz
08-31-2005, 06:42 PM
Retail $216, got it thru my mechanic $160+case of beer
Google
Web AF
