98GT drop in replacement
Google
Web AF
slimfatboy
08-23-2005, 12:24 PM
Is the '03 3.8II a drop in replacement for a 98 GT? What issues would be involved with such a swap? TIA, Ted
BNaylor
08-23-2005, 01:09 PM
Is the drop in Series II 3800 with supercharger or normally aspirated?
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
slimfatboy
08-23-2005, 01:11 PM
its an NA engine
BNaylor
08-24-2005, 02:48 AM
its an NA engine
It should be a shoe in. Even your PCM module should work. All the wiring will match up. After the swap out you will need a case learn performed due to the new crankshaft position sensor.
Google
Web AF
