6 CD Changer
Google
Web AF
roaingphantom
08-22-2005, 11:25 AM
hello guys,
I was wondering if anyone can confirm this. I currently have a TB LS 2004 with a single cd changer. I can get a 6cd changer for about $150, however i was wondering if it would work. The part number is 10357886, if it would work since i was told it is from a GM vehicle and should work on TBs also ( it does look exactly like mine) would there be any additional stuff i would need to do other than swap em? Please advise.
Thanks so much.
coolblink
08-22-2005, 12:17 PM
you would need the dealer srv dept to program your vin # into the radio for it to work should not be more than $50-$100 maybe even free what i would do is call your service advisor and see how much he would charge you before you get it but even at $100 + $150 thats still a great price if you compare it with how much it would be staigh from the dealer
roaingphantom
08-23-2005, 01:51 PM
thanks guys. Turns out the dealer will charge 49.99 in nyc so i may be all set. I'll miss my casette player because of my IPOD but i guess i will do the FM modulator thing.
coolblink
08-23-2005, 02:31 PM
thats great to hear just one thing with the fm mod make sure u get a wired mod not a wireless because if you get a wiresless mod u will get this high wining sound (feedback from the speakers) and its going to drive u crazy it does with me i have a dvd player with a wireless and man its horrible so im fanally going to get a wired one this weekend any way my 2 cents
ginzy
08-23-2005, 04:42 PM
Yes Coolblink is correct, I had a bad experience as well with these wireless mod. Be sure to use a wired one and try to secure the modulator away from any other wiring in the dash and use a separate ground connection.
balboasdelight
08-23-2005, 05:08 PM
How does the wired FM mod connect to the head unit? Is there an auxiliary antenna input -- or do you have to install a switch to select between the FM mod input and the FM antenna input?
Thanks, I have a whining wireless FM mod on a DVD as well.
coolblink
08-23-2005, 07:16 PM
dont know exacly yet and dont want to give wrong info i know it goes throught the antena but all tell you all step by step on monday
ginzy
08-24-2005, 05:31 AM
[QUOTE=balboasdelight]How does the wired FM mod connect to the head unit? Is there an auxiliary antenna input -- or do you have to install a switch to select between the FM mod input and the FM antenna input?
O.K , The Fm mod has Audio L & R inputs, Car antenna (IN) slot, ground & positive wires and a antenna jack ( OUT) to hook to your factory head unit.
1- The RCA audio cables Left & Right of DVD goes to input in the FM mod.
2- The stock car antenna wire plugs in car antenna slot of FM mod.
3- Hook up the ground & positive wires.
4- The antenna jack from the FM mod goes to your factory head unit.
This would solve your problem.
ScarabEpic22
08-24-2005, 06:12 PM
Where do you get a wired FM modulator, and how much. I have a wireless one that sucks, and I have the 6 cd in dash with Bose, so an aux adapter is incompatible(at least for the 02s). Thanks for the help.
coolblink
08-24-2005, 07:28 PM
here you go try this if not look on ebay (man i love ebay)
http://www.circuitcity.com/ccd/productDetail.do?c=1&oid=80974&key=48246&com.broadvision.session.new=Yes&BV_SessionID=@@@@1419694226.1124926066@@@@&BV_EngineID=ccdcaddfhlklddicfngcfkmdffhdfgo.0
Google
Web AF
