clutchbbllr130 08-20-2005, 05:52 PM Help! clutch pedal goes to floor! offers little to no clutch happend fast didn't heaer feel anything, new clutch thanks st GTP Dad 08-21-2005, 10:10 AM You didn't say what year but if you have a hydraulic clutch you probably will need to replace the slave cylinder on the clutch. When these go bad the pedal will go right to the floor and not engage the clutch. Also before changing anything if the clutch is hydraulic check to make sure the fluid level is proper. If you have a mechanical clutch linkage you probably have a damaged clutch rod or damaged fingers on the clutch. bbllr130 08-21-2005, 04:20 PM Saved the day again GtpDad, bad slave cylinder. Thanks again Shawn vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
