97 blazer rear lift gate glass hatch don't workgreenblazer72 08-19-2005, 02:21 PM My blazer's rear glass hatch interior button and outside button with key lock doesn't open the hatch don't recall hearing if the solenoid kicks on or not ,is there a relay to this set-up and how to get it opened manually. BlazerLT 08-19-2005, 02:56 PM Go out and push the button and listen for the mechanism actuating. If there is no sound, I would look at seeing if there is a blown fuse in the fuse panel for it. travis2822 10-14-2005, 04:55 PM I have the same problem. I do hear it trying to work but it is weak and doesn't work. I've tried to do the emergency release but I am unable to release it that way. Has anyone had to do it that was successful that could give me some direction. Whiskers1 01-07-2006, 04:52 PM Same problem, in a 93. Fuses all check out OK. Multimeter indicates no power to wires, anyone know where the relay is for this? tom1121 11-02-2007, 02:07 AM Hey i got a 95 . if you have had any trany work done lately that could be the problem . look under the driver side door at the trany. there is 2 wire gangs hooked by the shifter if these are loose or unhooked the rear hatch will not open. ijust replaced my trany thats how i found problem. ZL1power69 11-02-2007, 09:24 AM Hey i got a 95 . if you have had any trany work done lately that could be the problem . look under the driver side door at the trany. there is 2 wire gangs hooked by the shifter if these are loose or unhooked the rear hatch will not open. ijust replaced my trany thats how i found problem. this thread is now over two years old. please refrain from bringing back old threads :nono: . vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
