F250 Ball Joint Replacement
Google
Web AF
gladius27
08-19-2005, 10:35 AM
Hi;
I'm about to do upper and lower ball joints on my 2000 F250sd and am looking for some advice. It looks like i have to remove the caliper, rotor, hub and CV....is this true? If not, how do i get the old joints out and the new ones in?
thanks
andy
oldspower_68
08-20-2005, 06:06 PM
on a superduty you will have to remove caliper,rotor,hub, and axle shaft. if you have automatic 4x4 you will need to replace the seals on the axle shaft or they won't work when you put them back together. also the hub(wheelbearing) can be a pain to get off good luck
gladius27
08-22-2005, 07:17 PM
Yea, boy did it suck. nothing wanted to come off.....but it's done
thanks
andy
Google
Web AF
