2 nd gear start
Google
Web AF
doyjt
08-18-2005, 08:20 AM
Hi new here
I have a 1994 Grand Prix SE 3.1 does not go into 1 st gear starts out in 2 nd is there a sensor for the second gear start and if so where is it?
Thanks for any help
hazzzmattt
08-18-2005, 08:22 AM
is chk eng light on?
doyjt
08-18-2005, 11:36 AM
comes on and off while driving but does not stay on
richtazz
08-18-2005, 11:44 AM
have the codes pulled, sounds like you have a bad shift solenoid that's not shifting down into first gear. Try some seafoam or Trans-X and see if it frees it up. Also try manually shifting it down into first to see if it goes.
doyjt
08-18-2005, 12:24 PM
Already tried manually shifting would not go in first. where would the shift silenoid be located on the trans.
psycho1
08-18-2005, 10:51 PM
I have a '95 GTP and it has a switch for second gear start (for driving in snow i guess) does your 94 have this and could that be the problem?
btw, if mine is switched on it shows on the dashboard.......
doyjt
08-19-2005, 07:11 AM
yes it has the switch but that is not the problem it seems to work ok.
richtazz
08-19-2005, 10:47 AM
The shift solenoids are in the valve body, and require the pan to be removed to service them. I would advise against attempting it yourself, unless you know what you are doing and have a clean place to work on it. Try the seafoam/Trans-x trick to see if it frees up.
Google
Web AF
