1984 300zx battery problems
RollingFellony
08-15-2005, 07:23 PM
anybody here might know the cause of the battery draining on me? I've checked the fuses and disconnected the factory alarm and it still drains. If anybody might know the problem it would help me out.
DeleriousZ
08-15-2005, 07:28 PM
could be shorting to ground somewhere in the electrical system, or your alternator could be going bad as well
RollingFellony
08-15-2005, 07:34 PM
just replaced the alternator, but on the alternator there is an 1 1/2 in cylinder look a like that i didn't put on cause the wire connected to it broke off, maybe that could be the reason.
longlivetheZ
08-15-2005, 07:54 PM
lol Yea...you need that...can't remember exactly what it is, but I think it's a fuse. Is it causing your problem, maybe...maybe not...but it's definately not helping the situation. Did the battery discharge constantly before you broke this off? No matter what...put it back on! Just cuz something breaks off doesn't mean you can just say "screw it" and toss it...lol
RollingFellony
08-15-2005, 08:01 PM
i'll try to ask around if i really need it. pretty sure i do, just dont want to take the alternator off again.thanks
longlivetheZ
08-15-2005, 09:43 PM
Shouldn't have to take the alt off again. Just replace the little do-hickey.
92rs25th
08-16-2005, 02:08 AM
Sometimes the battery can hold a volt charge but loses it's amperage over night , causing you to think something is draining the battery or vice versa.
longlivetheZ
08-16-2005, 06:29 PM
Uh...what?
crx1989
08-19-2005, 10:30 AM
You can't by the voltage. An almost drained battery can sometime still give you a 12V reading. Turn on the radio or lights and the voltage will drop considerably on a dead battery.
ExTrEmEDrIfT
08-20-2005, 03:47 PM
i think that cylinder thing you are referring to is the voltage regulator.. if so ofcourse you need it without a doubt .
longlivetheZ
08-21-2005, 09:30 AM
Yea...it's something like that...don't remember exactly. You definately need it, though...
RollingFellony
08-22-2005, 01:47 PM
thanks guys i''ll put it back and try to figure it out.
longlivetheZ
08-22-2005, 05:52 PM
Cool...good luck.
And btw...it's "felony", not "fellony"...just my :2cents:
RollingFellony
08-23-2005, 09:48 PM
i know that ,but there was two ll's in rolling. gotta look cool and drive hard.
longlivetheZ
08-24-2005, 03:26 PM
lol...whatever works, man...:p
