Problems Solved...
Google
Web AF
VBTahoe
08-15-2005, 06:25 PM
One of the things that frustrates me about this board and others is that there are many people posting problems, and many people posting (possible) answers, but very few people come back and state what fixed their problem. So, I'll put my money where my mouth is:
(Feel free to post your problems and their solutions here. I would be willing to assemble them all and post them in an orderly manner later)
1.
PROBLEM: Rear Lower Brake Lights inoperable when brake pedal pressed. Upper LED's functioning. When all lights where turned on, the rear (red) lights came on, so it was not a bulb problem. Hazards Inoperable
SOLUTION: Replaced Turn Signal Switch (also known as a "Multifunction Switch") attached to the steering wheel. Problem Solved.
2.
PROBLEM: When Right Turn Signal was pressed, rear back-up lights would flash as well as right turn signal. No such problem with left turn signal.
SOLUTION: Short circuit in wiring harness for towing, spliced wires. Problem Solved.
3.
PROBLEM: Leak on Passenger Side Floor after A/C was turned on.
SOLUTION: Cleaned out the A/C drain using Compressed Air. Problem Solved.
bigrick2179
10-24-2007, 09:21 PM
where did u find the end of the drain hose is it near the frame having hard time finding mine
maxwedge
10-25-2007, 04:07 PM
This thread is 2 years old , please start a new one, thanks.
Google
Web AF
