1999 Millenia t-belt replacement...questions...
thafaz
08-15-2005, 09:57 AM
Hey all,
I'm currently replacing the t-belt/waterpump on my 1999 Milly S; quite a job, I must say. I'm at the t-belt, but the diagrams from the manual do not match what I have in front on me....they say TDC, and the cam spockets should line up vertically, facing each other. On mine, they're both around 7 o'clock. Car ran fine when I took it apart...should I just follow the marks I made and be done with it?
Also, does anyone know the function of the 'seal plate'? I broke a bolt trying to tie it down...stupid me, grab the wrong bolt. Now I'm wondering if it's worth the time to drill it out. I think said item is used to isolate the block from the t-belt assembly and to provide a mating surface for the t-belt covers, but I'm not sure. Anyone?
Thanx,
FH
mazdatech177
09-07-2005, 03:48 PM
as long as you are confident about your custom marks then go with them. but if you are hesitant there SHOULD be a yellow mark on each cam sprocket that will line up with a notch on each valve cover. the crank sprocket will have a locator pin that will be placed in the 12oclock position. there will be a notch on the oil pump behind the sprocket and a "V" cut into one of the teeth on the pulley to let you know the marks are correct. this is a non-interference engine so if you do have the timing off you wont do any damage by mistiming it. the design of the engine already uses retarded intake cam timing. i wouldnt worry about the bolt you broke off, as long as it was just for the shield.
