spark plugh gap
Google
Web AF
castillorio
08-14-2005, 04:37 PM
i got some bosch platinum and i would like to know what the gap is. i went on ngk.com and it says its.032 and i just wanted to know if that correct. oh yeah i have a 96 taco 2.4.
thank in advance
mark
Brian R.
08-15-2005, 12:04 AM
4202 PLATINUM PART 2RZ-FE; Gap=.032
FR8DPX PLATINUM PLUG 2RZ-FE; Gap=.032
4301 PLATINUM2 2RZ-FE; Do not Gap
4418 PLATINUM+4 2RZ-FE; Do not Gap
I suggest you use the factory-recommended NGK or Denso plugs and not Bosch. I have heard the resistance of the Bosch plugs is different than that of the NGK or Denso plugs and may cause problems with your ignition.
castillorio
08-15-2005, 02:51 AM
thanks brian ill think about ngk.should i use ngk wires to? or accel?
Brian R.
08-15-2005, 12:19 PM
Use the factory wires.
castillorio
08-19-2005, 03:38 AM
well i just took off my spark plugs and the the gaps range from .036 to .045 and i put the new plugs at .032. would this improve anything cause i did feel a difference.
Brian R.
08-19-2005, 09:55 AM
New plugs always help somewhat. There is no harm in carefully installing good plugs.
castillorio
08-20-2005, 03:41 AM
brain i was wonderin if you change your wires you get more horsepower is that true or no?
Brian R.
08-20-2005, 03:46 PM
Only if the original set is malfunctioning. You can loose hp by installing junk.
castillorio
08-22-2005, 03:07 AM
really how? if u dont mind telling
Brian R.
08-22-2005, 01:08 PM
As I mentioned above, I have heard that some brands of spark plugs have different resistances than that of the OEM plugs. This may cause problems with the ignition system. The same would hold true for the wires. Also, some brands of wires would be much more prone to breakage and have defects just from installation.
castillorio
08-23-2005, 02:56 AM
oh really. i didnt know that. cause i thought if i bought some new wires i could sqeez a little more power from the engine.
Brian R.
08-23-2005, 10:35 AM
If you're missing on one or more cylinders, then check the wires and replace them as needed. If you aren't missing, don't bother.
Google
Web AF
