Transaxle RefillDByrd 08-13-2005, 12:08 PM I can't find any filler plug on my 2000 Camry V-6 A/T differential. My Haynes manual shows one and it says that the diff. unit is separate and must be individually filled. I am hesitant to drain the unit if I cannot find the way to refill it! I did my '98 Camry 4-Cyl. differential last year and the filler was easy to find on that unit. I have looked with lights and mirrors and there simply is NO filler plug on this diff. in my 2000 V-6. What's the deal. Will it fill from the A/T unit? Thanks csaxon 08-14-2005, 12:38 PM You don't have one. Older models did . You fill it through the transmission dip tube. If you look where the old refill hole used to be it's probably a solid cast indention. Luke Home 10-12-2007, 03:27 PM You don't have one. Older models did . You fill it through the transmission dip tube. If you look where the old refill hole used to be it's probably a solid cast indention. If this is the case, it is necessary to drain the fluid from the differential drain plug as well? Or is draining the fluid from the trans axle pan drain plug good enough? Or do you need to drain from both before refilling through the Trans Oil Dip Stick/Fill tube? Thanks, Luke DL175 10-13-2007, 08:35 PM There is a filler hole and it is located where the front wheel of the driver side is. It is impossible to see unless the wheel is removed. Once the wheel is removed you will see it. Look down where the bottom of the transaxle is located. It is a 17 mm bolt with a large washer. The drain bolt is a bolt with a 10 mm hex hole inside near the side. Note the filler bolt is difficult to reach and you will need a 1 foot socket extention for your socket to reach the bolt. Also the filler bolt will be hard to get off if it is the first time take out. Luke Home 10-13-2007, 10:14 PM There is a filler hole and it is located where the front wheel of the driver side is. It is impossible to see unless the wheel is removed. Once the wheel is removed you will see it. Look down where the bottom of the transaxle is located. It is a 17 mm bolt with a large washer. The drain bolt is a bolt with a 10 mm hex hole inside near the side. Note the filler bolt is difficult to reach and you will need a 1 foot socket extention for your socket to reach the bolt. Also the filler bolt will be hard to get off if it is the first time take out. I think not .... see pictures at the bottom of this post: http://www.automotiveforums.com/vbulletin/showthread.php?t=738494 Thanks anyways! DFBonnett 10-14-2007, 07:17 AM DL175 10-14-2007, 08:17 AM I see your transmission is different than mine. Mine is a 1998 V6 XLE made in Japan. Mine has a bolt to fill the differential but it seems yours doesn't. Luke Home 10-14-2007, 06:25 PM This is my point exactly ... Am I missing something or is it a fact that the 1999 (v6) Camry has some trannys out with and some without a separate differential compartment that needs drained/filled????? Brian R. 10-15-2007, 01:21 AM I have been told that 1999 and newer differentials do not have fill plugs and are filled from the transmission. They are drained through the drain plug. 1998 and older have fill plugs and are filled that way. somick 10-15-2007, 01:08 PM Hey, guys! Pay attention to the dates. You are discussing a two year old thread!!! Sam Brian R. 10-15-2007, 02:25 PM This has been turned into sort of a general topic thread. They are more acceptable for this purpose. The "How do I Fix my Front End Noise" types of threads are less acceptable in this way... xfeejayx 10-15-2007, 02:54 PM you tell em' Brian. :) btw, does this apply to the 4cyl engine also? Do the I4 and V6 share a trans and/or diff? I'd assume not. That would mean that either the trans is on the edge on the v6, or a little robust for the I4 (boost anyone?). Brian R. 10-15-2007, 09:31 PM The transmissions/differentials are different for the V6 and the I4. This does apply to the 4 cylinder differentials. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
