leaking antifreezeslimshadygirl100 08-13-2005, 10:19 AM I have been smelling antifreeze ever since i got my oil changed 2 weeks ago. Sometimes it smokes if i have car running to long. Car doesnt over heat. I have to add antifreeze like every other day, i dont notice any leaks though!! HELP!!!!!!!! Ryan066 08-13-2005, 10:47 AM prolly leaking around a freeze plug on the block. and is it bubbleing in the overflow tank? milky oil? start the car and run it so its at operating temp and just look at the front of the block... by the sounds of it you should see it leaking.. check around the exhaust manifold at the rear of the block. other then the freeze plugs it might be leaking out of the water pump/hoses.. slimshadygirl100 08-22-2005, 12:57 AM thanks for the reply, it was my water pump!! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
