Rear door latch question
Google
Web AF
conlon132
08-13-2005, 03:37 AM
Does anyone know about, or had to fix/replace the door release mechanism on the driver side rear barn door? After opening the passanger rear door, I went to pull the driver side door, but realized there was no tension in the handle, and the door wouldnt open. After removing the inside panel, I notice the latch mechanism came apart inside. It appears that a bolt that helt the latch to a spring is missing, but there do not appear to be any threads on the rod. How do I reattach the latch to the bolt and spring??
nosefirst
08-13-2005, 06:40 PM
The spring will be down inside the door cavity. If your lucky the push nut will be too. Otherwise you'll have to go to the hardware store and get one 3/16 I belive. Un snap the rods out of the plastic clips first and the task will be easier.
mrgoodwrench69
08-17-2005, 10:59 PM
The same thing happned to my 97' about 2 years ago. One of the plastic pieces that holds one of the rods in place broke from my kids slamming the door to hard. I went to the dealer and got it for about $3.00.
biznazion
12-08-2007, 01:40 PM
I'm trying to fix this exact problem on my '99 Tahoe. I've taken off the panel and I can see that the latch, rods and spring are all still there. The only part I have found in the door is a washer - and when I fit it all back together, I can't see any way to hold it together. The end of the post that goes through the spring and holds the piece that the rods attach to doesn't have any threads - nor does it stick out past the washer at all. I can see a round mark on the actuator - so I'm pretty sure that's where the washer came from, but I'm totally at a loss of how it was held together.
nosefirst
12-14-2007, 11:46 AM
What you need is called a "pushnut". No threads. My local Ace hardware has a nice selection. Check yours. 3/16 I believe.
Google
Web AF
