2004 Cavalier Stereo Questions
Google
Web AF
colinlesser
08-12-2005, 04:38 PM
i just bought a 2004 CAV 2dr (18,000miles) for $6,000 + My 94 Lincoln TC and i got a few questions after i did a few searches here so here goes
1. i wanted to change the factory single cd out for my aftermarket cd player but it just seems likea pain in the arse so im just gunna leave it but i want to attach my amp and sub so can i splice the rear speakers and attach RCA wires without messing anything up?
2. what are some sites with CHeap body kits?
3. the chevy dealer said that the standard factory warranty only cover defective parts is that normal?
4. any know problems with the 04?
5. does the CD palyer only recive info from radiostations? or can it read CD's with certain tags? or CD/R's
colinlesser
08-13-2005, 09:41 AM
anyone?
colinlesser
08-13-2005, 03:12 PM
33 views and not a single reply? wow
colinlesser
08-13-2005, 06:46 PM
come on now almost 2 days and 41 views later and still no replies? did yall fall in or somthing?
colinlesser
08-14-2005, 07:45 PM
ok this is absolutely deplorable do people not answer questions anymore? 51 views and counting
colinlesser
08-15-2005, 05:01 PM
64 views and 4 days later still no responses
Ryan066
08-15-2005, 05:13 PM
splice the wires you want... andd use a voltmeter to see if they are 12 V ... then u might be able to use them but most amps are hooked up directly to the battery.
body kits .. bleh..
what else would be covered by warrenty other then defective parts?? I dont think rust and corrosion is covered and I know maintiance is not covered by warrenty.
04... prolly a the heater resister... if its rusty then exhaust hanger mounts rust off... other then that i will tell you in a couple months.
I would guess that the factory cd player will play all cd's (burned or not) and receive all radio stations..
FinchUsed
08-15-2005, 05:33 PM
1: I dont know anything about stereo systems so I wont say anything on that.
2: Cheap body kits? Ebay has super cheap ones but you risk them not fitting or being so cheap they break on you just after being put on. Google search Cavalier Body Kit and Im sure you'll find stuff.
3: Yeah thats normal as far as most warranties go these days it seems.
4: The 2003 has a rather cheap IAT sensor. You may want to replace yours with an aftermarket instead of the factory ones which have tiny wires. They can cause problems, though probably minor ones.
5: The factory CD player should play CD as well as CD-R/RW. If it doesnt then GM is stupid.
colinlesser
08-15-2005, 05:56 PM
but can the factory read the names of cds and tracks?
Ryan066
08-15-2005, 06:01 PM
should be able to because that info is recorded onto the CD.. if it does with regular bought cd's.
test it?? you got nothing to loose:p
Google
Web AF
