"""94 ex CIVIC idle surge""""
94civicvtecex
08-12-2005, 01:43 AM
Why does my supercharged civic's idle go up and down once I start my engine. It didn't do it when I installed the JRSC, but this past winter it started surging...more when cold. It's none of the common things(vaccum, IACV,etc). I think it's something to do with the cooling system, or 02 sensor, or something else....... I'm not sure help.
fasthatchb18c1
08-12-2005, 02:41 AM
are you throwing a check engine light?
superbluecivicsi
08-12-2005, 12:22 PM
a better description of your surging would be nice.
how do you know its not a vac leak? you checked the vacuum with a gauge? if you did then what is the actual readings? how do you know its not the iacv? all vac lines and fuel lines are where they are supposed to be? compression results show?
scottsee
08-14-2005, 12:41 AM
Second that
Schister66
08-14-2005, 11:20 AM
i thought right away that it was either vaccuum or the IACV (idle air control valve), but i guess not.
Anthony02007
08-25-2005, 03:10 PM
did u try cleaning the throttle body out good with carb cleaner
Anthony02007
08-25-2005, 03:11 PM
that was for 94civicvtecex
Anthony02007
08-25-2005, 03:14 PM
has ne one heard about this sport compact pro sponsorship thing whats the story be hind it?
blitzcivic
08-29-2005, 06:07 PM
i had the same problem with my civic it is a simple fix you have to order from the dealer a fast speed idle valve. it is located under the throttle body and is connected to a coolant line.
