Blockguard???djK1 08-11-2005, 09:06 PM OK, So I so again i'm planning on running 1 bar or 14.5lbs of boost. I have crower pro rods and cp 9:1 comp. forged pistons. I read that the crank can handle 400 hp and so i'm not replacing that, I'm trying to get out of this as cheap as possible. So I only want to crack the block open once and be done with it. So I have seen 2 different designs for blockguards / sleeve savers. there is the scalloped design That has big grooves cut outs along the edges or the basic solid rings with holes drilled in them. Know I hear that the scalloped guards are designed for better coolant flow, but are they as strong? Do you have a preference or experience with either one of these designes? do you think I should spend a lot more money and just get it sleeved? Anyways let me know what you think, especially if you know what your talking about. darkness CivicSpoon 08-11-2005, 09:23 PM Do it right and get it sleeved. Do a search for why the block guards can creat big problems for you. 97integrals 08-12-2005, 12:12 AM In my opinion you would be better off running with out the block gaurd and just getting a really good tune. Best case would be to sleeve the block, block gaurds do way more harm than good. What engine is this and what turbo? djK1 08-12-2005, 08:35 AM b16a, turbonetics t3/t04b, what kind of harm does a blockguard do??? The only thing I have heard about are hot spots in the engine due to improper coolant flow. 97integrals 08-12-2005, 01:56 PM b16a, turbonetics t3/t04b, what kind of harm does a blockguard do??? The only thing I have heard about are hot spots in the engine due to improper coolant flow. Block guards are a total waste. They do nothing for increasing structural rigidity in a non-knocking condition that a properly tuned engine operates within. The block guard will not save the sleeves; they will crack if the engine knocks. They also expand at a quicker rate because they are made out of a different materiel than the sleeves, typically 6061 aluminum, this rapid expansion causes them to oval the cylinders. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
